Flashforge Creator Left extruder prints off center
Posted: Sun Feb 02, 2014 1:27 am
by davedfx
My Left extruder is printing off center. Right extruder prints fine.
I know i can manually offset in gcode offset but is there a way that this is done automatically?
In makerware and other slicers I don't have this problem
Re: Flashforge Creator Left extruder prints off center
Posted: Tue Feb 04, 2014 10:52 pm
by dnewman
Truly this sounds like your toolhead offsets in the EEPROM (onboard parameters) for your bot are off. The gcode for
dualstrusion assumes there is NO offset between the extruders. The full offset is handled by the firmware and the
amount of that offset is set in the bot's EEPROM, at least for Makerbots and clones such as the FF Creator.
Dan
Posted: Sat Apr 19, 2014 5:51 pm
by peacetemple
Hello I'm experiencing the same problem, ... have you found a solution ? thanks.
Posted: Sun Apr 20, 2014 10:40 pm
by Bagelturf
This sounds just like this issue I reported a while back with the Rep 1 Dual. I've not had time to try 2.1.0 to see if it is present there.
http://forum.simplify3d.com/viewtopic.php?f=9&t=754
