S3D PLA defect fix
Posted: Mon Dec 05, 2016 11:37 am
by jim2386
Hi all,
I'm trying to tweak in my S3d profile settings for PLA using my lulzbot mini. I loaded the latest profile and I've been noticing some defects I can't get rid of, yet Cura seems to handle things perfectly. If anyone has some suggestions on how I could fix these small issues, please let me know.
So far I've tried turning down the flow rate %, I've increased retraction from 1.5 to 1.7, I've tried extra cooling, I've tried adding Zhop (This is actually why cura shows stringing...Adding Zhop increased stringing in S3D as well on a different print)
I'm not sure what else to try. Any suggestions?
FFF file posted below
Thanks
Jim
Re: S3D PLA defect fix
Posted: Tue Dec 06, 2016 4:54 am
It looks like it's most likely your retraction settings since the dots seem to be at the start or end of the perimeters. So this is a good guide to start with: https://www.simplify3d.com/support/prin ... s-and-zits
Posted: Tue Dec 06, 2016 2:14 pm
by jim2386
I've upped my retraction distance a bit without any change at all to the print.
Would you suggest I try messing with "extra restart distance" and, since it looks like it's over extruding, put in a slight negative number to prime the nozzle less?
Thanks
Jim
Posted: Wed Dec 07, 2016 7:29 am
Yup, that's one thing you can try. The link above explains how to determine if you should be using negative extra restart or coasting, so be sure to give it a good read ;)
