Problem: temperatures get mixed between ABS and PLA
Posted: Tue Apr 04, 2017 10:12 pm
My S3D profile has three materials, PLA, ABS, and PTEG. If I change extruder temperature for PLA and then switch to ABS, S3D should remember the extruder temperature of ABS, right? That is, each material has its own independent temperature settings.
I am pretty sure they used to be independent but now when I change temperature in one material it affects all.
The only relevant profile changes I can recall are deleting the right extruder and renaming Left Extruder to Extruder.
Attached is a copy of the profile file.
Any suggestion will be greatly appreciated.
