Domes in TPU print "foamy"
Posted: Mon Apr 10, 2017 5:02 pm
by Skwerl
I've found that when I print objects out of TPU with dome-like features, the tops of those domes are more opaque and have a foamy look to them compared to the rest of the object. The change from semi-transparent to foam cap occurs in just one or two layers- not gradual- see photo link below. I've made sure that there aren't any flat layers being printer in these areas and have tweaked the temperature settings quite a bit and looked for interesting things in the build previews, but I haven't solved this yet. Has anyone else noticed this or have some other suggestions on what to examine?
Thank you,
Josh
https://1drv.ms/i/s!AhAeBy_bs4Czlo4ZvL1gj_m6yA3JbQ
https://1drv.ms/i/s!AhAeBy_bs4Czlo4XaPDck-M533wdwg
Re: Domes in TPU print "foamy"
Posted: Wed Apr 12, 2017 9:48 am
by pixel3design
Humidity and temperature issue... TPU is quite hard to print without bubbles...
Posted: Fri Apr 21, 2017 2:46 pm
by MasterFX
I got the same on TPU if I printed it to slow and/or to high temperature. If you slow down the speed (which happens on S3D in default when the layer print time is smaller than 15 seconds, see cooling tab) you have to lower the temperature.
Make a test piece with varying temperatures and speeds (use different processes starting at differenz heights) to find the sweet spot
