Connecting Macbook to Maker select plus via USB
Posted: Wed May 03, 2017 3:03 pm
by Sabotage
I for the life of me connect via USB to the Maker select plus via USB , I went into about mac and clicked report and saw it there but when I try to find it via the software I cannot find it anywhere..Under ports it only has my Iphone and incoming bluetooth on the software. What baud rate should i use for the macbook ??? Thank you 8-)
Re: Connecting Macbook to Maker select plus via USB
Posted: Thu May 04, 2017 7:40 am
by brian442
Are you able to connect to it from any other software programs? Is the printer powered on?
Posted: Thu May 04, 2017 3:07 pm
by Sabotage
No, not at all .. It super frustrating..The printer is on .. What in the sams hell can it be??
Posted: Fri May 05, 2017 10:28 am
by Dero
When your printer is on and connected to your Mac via USB, 2 USB ports should be listed next to the Connect button, xxxxbluetoothxxx and xxxserialxxxx. If the xxxserialxxx is not listed, you may not have the USB-serial drivers loaded. Go here and download and install::
http://www.ftdichip.com/Drivers/VCP.htm
I can't remember if the Mac needed rebooting afterwards, but it worked for me.
