Page 1 of 2
Not printing details of stl file
Posted: Fri May 19, 2017 4:49 pm
by carlbeck
As Shown when imported
I have 2 stl files that will not print as shown in the stl import.
Re: Not printing details of stl file
Posted: Fri May 19, 2017 7:01 pm
by Jeff_Birt
Typically attaching the factory file will get you more help. There is just no way to see the problem from pictures.
Posted: Fri May 19, 2017 8:21 pm
by carlbeck
endcap.factory
(7.05 KiB) Downloaded 297 times
Here is the Factory File.
Posted: Fri May 19, 2017 9:23 pm
by Jeff_Birt
Go to the advanced tab and deselect 'merge all outlines into single model'.
Posted: Sat May 20, 2017 9:08 am
by carlbeck
Thank you very much. I would have never thought of that. I assumed when you installed it, those boxes would be correct for default printing. But: Then again I know what it means to ass u me. :)
Where can I find the description of what each of those check boxes really do in Simplify3D?
Posted: Sat May 20, 2017 1:43 pm
Posted: Sat May 20, 2017 2:22 pm
by Jeff_Birt
dkightley wrote:viewtopic.php?f=9&t=7497
I'm not sure what the post you linked to had to do with this thread?
Posted: Sat May 20, 2017 2:57 pm
Read the thread! It contains a list of other threads that contain explanations for every setting on every tab of the profile.
The answer to the question "Where can I find the description of what each of those check boxes really do in Simplify3D?" is in one of the threads. You just have to look for it.
Posted: Sat May 20, 2017 8:37 pm
by Jeff_Birt
There is no list in that thread. Maybe you pasted the wrong link :)
Posted: Sun May 21, 2017 8:56 am
by Jeff_Birt
I think maybe you meant this thread: viewtopic.php?f=8&t=2367
