Copy and paste object on build platform?
Posted: Wed Mar 12, 2014 11:50 pm
by andre
Is there a way to duplicate objects on the build platform instead of loading each one?
My issue is in trying to print a few of a part, which needs to be rotated. Hence, I need to load each one individually, then double click on the part, then type in the new xyz rotational coordinates. Time consuming. Would be great to load one, rotate it correctly, then copy that same one multiple times.
Re: Copy and paste object on build platform?
Posted: Wed Mar 12, 2014 11:53 pm
by andre
Ooops, looks like menu item Models->Duplicate Models does it!
Now I only wish I could rotate the model in real time instead of having to hit "Save" everytime.
Posted: Thu Mar 13, 2014 5:36 pm
by JoeJ
You can rotate in real-time using Alt + left click
Posted: Fri Mar 14, 2014 9:05 pm
by tri-lite
Or if you're on a mac, Option+Click rotates your model
Posted: Sat Mar 15, 2014 8:07 pm
by andre
You can only rotate in the Z. I need the ability to rotate in X and Y. Having to click SAVE, then realize you have the wrong amount, going back to the screen and doing it again, is extra work. Looking for at least 90deg in each axis, one click rotates so you can view.
Posted: Sun Mar 16, 2014 3:08 am
by ronsand
It would help if you had the option to press "apply" within the settings box, and have the model rotate or move without closing the box
Posted: Sun Mar 16, 2014 4:36 pm
by andre
Or, just have the model rotate live as you change the settings.
Posted: Sun Mar 16, 2014 8:52 pm
by tri-lite
Nice suggestions - agree it would be great to see them on an upcoming release.
