Can no longer drag model to build plate
Posted: Tue Jul 18, 2017 7:28 pm
by labmat
I just installed the latest Simplify3D 3.1.1 on my Windows 7 machine and I am not able to drag a model into the application. When you try you get the circle with line through it. I have reverted back to 3.1.0 as that release does not have this issue. Is this a known issue?
Thanks,
Matthew LaBerge
Re: Can no longer drag model to build plate
Posted: Wed Jul 19, 2017 4:03 am
by brian442
Works fine for me on 3.1.1 with my Windows computer. Can you post the actual file you are trying to drag in? Also, make sure that the software is ready to import a model and you don't have any other popups on the screen (for example, you may not be able to drag in a model if you have the you are editing your process settings, so close out of those windows)
Posted: Wed Jul 19, 2017 9:46 am
by labmat
The issue affects every model I tried from multiple different sources, USB thumb drive and two different internal SSDs. I tried both downloaded .stl and stl files I created in Creo. I am not editing any process settings so there are no popups blocking me. I am able to bring in every model I tried dragging by using the import model button. Like I said when I switch back to 3.1.0 the issue is non existent. I guess I can try uninstalling and reinstalling.
