MKS SBASE 1.3 trouble connectiong
Posted: Tue Oct 24, 2017 3:35 am
by Espaider
Hi, I can not connect my printer using USB to S3D.
I select the right baud rate (115200) and have tried with both USB ports that show up when I plug the printer but I get:
Attempting connection at \\.\COM11...
Permissions error connecting to port
Is there another application already connected to this port?
Error opening selected port.
Any ideas, solutions?
Re: MKS SBASE 1.3 trouble connectiong
Posted: Tue Oct 24, 2017 6:14 am
by brian442
They have an FAQ section about this, so you might want to start by reading that:
https://www.simplify3d.com/support/faq/#faq-4630
Posted: Fri Nov 10, 2017 9:15 am
by deafoldgit
brian442 wrote:They have an FAQ section about this, so you might want to start by reading that:
I am also having this problem, I did read the above and did as it said, but I still get the same problems, machine is Vertex K8400 twin extruders
Posted: Wed May 09, 2018 7:48 pm
by pnelson29
I am also having this issue, after updating my firmware.. The Baud is set for 115200 on my COM 3 in devise manager, in S3D and in my Marlin sw..
I haven't been able to connect since..
Posted: Wed May 09, 2018 7:59 pm
by pnelson29
And YES I read this... I can connect that way.. But i can't do anything with it.. So it is useless
Might want to read this:
Posted: Thu May 10, 2018 3:31 pm
by DarthRevan
This error typically means another software is open and already connected to the port you attempted to open a connection with.
Do you still have the Arduino IDE open or another 3D printer controller software open? If so, try closing them and then clicking connect in S3D.
