Elephant paw cube
Posted: Tue Nov 21, 2017 5:28 am
by gpau
Hi, what settings should I edit to print the cube correctly.
I put pictures I hope they are understandable.
Thank you
Re: Elephant paw cube
Posted: Tue Nov 21, 2017 8:26 am
by arhi
the standard elephant's foot solution consist of combination of:
- before anything else - make sure your bed is leveled properly
- lower heated bed temp
- increase cooling of 2nd+ layers
- raise a nozzle a bit (the 0 height of the nozzle, get it up a bit, you can do that using Z offset in advanced settings)
