Thin exterior wall seperation from solid body
Posted: Tue Jan 30, 2018 9:32 pm
https://www.dropbox.com/s/cfhri1rm0pxjg ... a.jpg?dl=0
I have a model created in OnShape. The bulk is a solid object, The exterior layer is separating from the rest of the model.
In the image above you can see the razor through the layer. It is bonded on the bottom where I have a
1mm fillet at edges.
I'm at a loss, all of my test prints have been almost perfect.
The wall on the cylinder is not separated. Only on the large flat areas.
Thank you for any help.
