Page 1 of 2
S3D v4.0.1 Bug Reports
Posted: Sun Feb 11, 2018 1:17 am
by TekMason
I just installed S3D v4.0.1 on a second PC here and immediately ran into some issues with it.
1. No Auto-Rotate View
View > Auto-Rotate View was not available. I have no idea of how to get it back or if it is even possible to.
2. Rendering Problems with Some Acceleration Modes
My solid objects (model and build plate/printer) were transparent. I loaded the same model on PC 1 that was running S3D 4.0.0 and all was fine.
Googling for the problem/solution netted nothing.
A comparison of settings between 4.0.0 and 4.0.1 revealed new configuration items in Tools > Options > Visualization > Acceleration Mode
This looked like a good place to start so I changed the value from Automatic to Disable Hardware Acceleration, restarted S3D and it fixed the rendering issue. Of course I couldn't leave 'well enough' alone and had to try the other settings. Compatibility Mode introduced the transparent rendering issue again.
Things really went sideways when I tried Native Hardware Acceleration mode. S3D would no longer start on my machine!
I tried almost everything including disabling all but the main monitor/video card, rebooting, registry hacks to disable video hardware acceleration in the Win10 OS, deleting the S3 settings in my user profile and uninstalling and re-installing S3D. Nothing fixed it.
Finally I recovered S3D when I went rooting through the registry and found the accelerationMode key and set it to 0. This changed the setting to automatic allowing S3D to start and then I promptly changed it to Disable Hardware Acceleration.
This is the full path of the registry key that sets the Acceleration Mode.
\HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software\MainOptions\accelerationMode
S3d 4.0.1 Acceleration Mode = Automatic (default) = BAD
S3d 4.0.1 Acceleration Mode = Disable Hardware Acceleration = GOOD
Hope this helps save someone else some time.
Cheers,
TekMason
Re: Problems with v4.0.1
Posted: Sun Feb 11, 2018 11:48 am
by horst.w
Auto rotate??? Rotate is a symbol on the taskbar on the right side (variable). In the main menue VIEW it is not listet (but I havn't missed it because never used).
If no object is loaded, the Rotate-Tool has no reaction but that seems ok.
Regards
GER
Posted: Sun Feb 11, 2018 3:56 pm
by TekMason
Auto-Rotate View does a continuous animation of a slow rotation about the Z axis.
Not a really important command but it can be a nice way to visualise your models.
Here it is in the v4.0.0 menu bar.
TekMason
Posted: Sun Feb 11, 2018 4:40 pm
by horst.w
ok, I'm sorry,it is here in my 4.0.1 installation. The dropdown-menue reachs to the ohter textes in the main menue and "Auto-Rotate" covers "Import / Remove"
H.
... also never used ;-)
really mysterios !!!
I ended S3D and restarted the program, the menue point was now not visible.
Posted: Mon Feb 12, 2018 5:31 am
by szafran
I'll add something here instead of creating separate thread. Hope this doesn't bother anyone...
no 3.
Wrong Z height shown - should be 0,2 and shows as 1mm
no 4.
Calibration STL downloaded from thingiverse - bridges are ok
I've created this one for better bridging calibration - bridges are all wrong (generated sideways - same settings as the above).
Posted: Tue Feb 13, 2018 7:54 pm
by TekMason
Hi szafran,
Might be be a good thing to keep v4.0.1 issues in the same thread. Perhaps it will get the attention of S3D support. With that in mind I have renamed the thread S3D v4.0.1 Bug Reports.
Could you edit you post though to make the items you discovered numbers 3 and 4. I've got 1 and 2 ;)
Cheers,
TM
Re: S3D v4.0.1 Bug Reports
Posted: Tue Feb 13, 2018 8:20 pm
szafran's second item......item 4 as per TekMason........is not a bug/issue. The bridging algoritm tries its best to determine the angle for the bridging extrusions. For where it's unable to reliably determine the angle, there's a setting Use fixed bridge infill angle, where the desired angle can be specified by the user.
Posted: Wed Feb 14, 2018 6:39 am
by szafran
In my opinion it is a bug (Slic3r cuts this properly). And what that option would do if on the same height there will be bridges in different directions ? (hint: it would be totally useless).
Posted: Sun Feb 18, 2018 3:32 am
by szafran
no. 5. The third process in the attached factory file should generate a brim attached to the object that is 5 outlines wide. Instead it generates a 1 outline skirt like for the rest of the objects.
Posted: Sun Feb 18, 2018 3:47 am
by horst.w
@ szafran
What ever you want to reach, your process settings are very faulty.
Try:
Skirt layers 999
Distance 2 mm or more
Outlines 1 or 2
H.
