TekMason
S3D v4.0.1 Bug Reports
I just installed S3D v4.0.1 on a second PC here and immediately ran into some issues with it.
1. No Auto-Rotate View
View > Auto-Rotate View was not available. I have no idea of how to get it back or if it is even possible to.
2. Rendering Problems with Some Acceleration Modes
My solid objects (model and build plate/printer) were transparent. I loaded the same model on PC 1 that was running S3D 4.0.0 and all was fine.
Googling for the problem/solution netted nothing.
A comparison of settings between 4.0.0 and 4.0.1 revealed new configuration items in Tools > Options > Visualization > Acceleration Mode
This looked like a good place to start so I changed the value from Automatic to Disable Hardware Acceleration, restarted S3D and it fixed the rendering issue. Of course I couldn't leave 'well enough' alone and had to try the other settings. Compatibility Mode introduced the transparent rendering issue again.
Things really went sideways when I tried Native Hardware Acceleration mode. S3D would no longer start on my machine!
I tried almost everything including disabling all but the main monitor/video card, rebooting, registry hacks to disable video hardware acceleration in the Win10 OS, deleting the S3 settings in my user profile and uninstalling and re-installing S3D. Nothing fixed it.
Finally I recovered S3D when I went rooting through the registry and found the accelerationMode key and set it to 0. This changed the setting to automatic allowing S3D to start and then I promptly changed it to Disable Hardware Acceleration.
This is the full path of the registry key that sets the Acceleration Mode.
\HKEY_CURRENT_USER\Software\Simplify3D\S3D-Software\MainOptions\accelerationMode
S3d 4.0.1 Acceleration Mode = Automatic (default) = BAD
S3d 4.0.1 Acceleration Mode = Disable Hardware Acceleration = GOOD
Hope this helps save someone else some time.
Cheers,
TekMason
Re: Problems with v4.0.1
Auto rotate??? Rotate is a symbol on the taskbar on the right side (variable). In the main menue VIEW it is not listet (but I havn't missed it because never used).
If no object is loaded, the Rotate-Tool has no reaction but that seems ok.
Regards
GER
TekMason
Auto-Rotate View does a continuous animation of a slow rotation about the Z axis.
Not a really important command but it can be a nice way to visualise your models.
Here it is in the v4.0.0 menu bar.
TekMason
ok, I'm sorry,it is here in my 4.0.1 installation. The dropdown-menue reachs to the ohter textes in the main menue and "Auto-Rotate" covers "Import / Remove"
H.
... also never used ;-)
really mysterios !!!
I ended S3D and restarted the program, the menue point was now not visible.
szafran
I'll add something here instead of creating separate thread. Hope this doesn't bother anyone...
no 3.
Wrong Z height shown - should be 0,2 and shows as 1mm
no 4.
Calibration STL downloaded from thingiverse - bridges are ok
I've created this one for better bridging calibration - bridges are all wrong (generated sideways - same settings as the above).
TekMason
Hi szafran,
Might be be a good thing to keep v4.0.1 issues in the same thread. Perhaps it will get the attention of S3D support. With that in mind I have renamed the thread S3D v4.0.1 Bug Reports.
Could you edit you post though to make the items you discovered numbers 3 and 4. I've got 1 and 2 ;)
Cheers,
TM
Re: S3D v4.0.1 Bug Reports
szafran's second item......item 4 as per TekMason........is not a bug/issue. The bridging algoritm tries its best to determine the angle for the bridging extrusions. For where it's unable to reliably determine the angle, there's a setting Use fixed bridge infill angle, where the desired angle can be specified by the user.
szafran
In my opinion it is a bug (Slic3r cuts this properly). And what that option would do if on the same height there will be bridges in different directions ? (hint: it would be totally useless).
szafran
no. 5. The third process in the attached factory file should generate a brim attached to the object that is 5 outlines wide. Instead it generates a 1 outline skirt like for the rest of the objects.
4.0.1 error - no brim.factory
(140.44 KiB) Downloaded 281 times
@ szafran
What ever you want to reach, your process settings are very faulty.
Try:
Skirt layers 999
Distance 2 mm or more
Outlines 1 or 2
H.
