Is this over extrusion and if so how do I fix?
Posted: Mon Mar 26, 2018 10:07 am
by jab136
I had a part fail last night because the nozzle caught on significant blobbing and the build plate came loose. I figured it was too much outline overlap, so I dropped that and it didn't resolve the issue, I stopped the print today because I saw that it was going to fail soon. Should I decrease the extrusion multiplier? I need 100% infill for the part for reasons other than structural, so please don't suggest that. I have attached an image of the part that I stopped today to show the blobbing, as well as the factory file, I am printing on a Raise 3d N2 plus dual, but I am only using the left extruder.
Re: Is this over extrusion and if so how do I fix?
Posted: Mon Mar 26, 2018 2:55 pm
by Credo
Have you gone through an extruder calibration to ensure the proper number of steps/mm? One of my printers came out of the box incorrectly calibrated. I'm glad I went through this process.
Check out this video for information:
https://youtu.be/YUPfBJz3I6Y His instructions are great. Tom has a lot of helpful videos.
Hope this helps.
Posted: Mon Mar 26, 2018 4:47 pm
by C4beard
Hi do you have any pics of the side of the piece
Posted: Tue Mar 27, 2018 8:14 am
by zemlin
What you need to do is run a square vase-mode test part with your extrusion multiplier set to 1.0.
Measure the wall thickness and compare it to your extrusion width set in the slicer.
Extrusion Width / Measured Thickness = Extrusion Multiplier.
It's a process you need to go through for every time you change material or setup. Fortunately a vase mode square prints quickly. Extrusion multiplier is not a trial and error thing.
Posted: Tue Mar 27, 2018 8:21 am
by jab136
isn't extrusion width set by the nozzle diameter?
Edit: also, I only work with one material, do I need to re-do the extrusion multiplier for each spool?
Posted: Tue Mar 27, 2018 8:44 am
by zemlin
jab136 wrote: ↑Tue Mar 27, 2018 8:21 am
It can be set automatically with nozzle diameter, or you can adjust it manually. Either way the process is the same.
You would want to repeat if you change layer height, temperature, or make a significant speed change.
Posted: Tue Mar 27, 2018 10:22 am
by jab136
zemlin wrote: ↑Tue Mar 27, 2018 8:44 am
what if I have significant underspeeds in my profile? I don't typically mess with temperature or layer height, but the outer shell is a 50% underspeed on that profile, should I calibrate the multiplyer to the underspeed or to the full speed?
Posted: Tue Mar 27, 2018 10:41 am
by zemlin
I haven't found this to be a big deal. I typically run at 50% on solid infill and outer perimeters. Speed might not be big factor. Haven't done a study on that. I just run a new calibration when I'm changing setup.
