Pause at layer
Posted: Sun Apr 08, 2018 4:04 pm
by amp1276
Please add the option to pause at a specified layer so that we can change colors. Also begin at layer would be good as well so that we can continue a stopped print.
Re: Pause at layer
Posted: Mon Apr 09, 2018 4:26 am
by rrdavis
There's already several ways to pause a print at a specific location.
You can also already use the "begin printing at height" option on the Advanced tab to resume a print at a certain Z-height.
Re: Pause at layer
Posted: Mon Apr 09, 2018 9:28 am
by airscapes
Lack of documentation seems to be a problem with S3D, the stuff they have on the site is good, just not even close to being enough..
This will explain the separate process.. and I saw a post or article someplace that explained how to add some gcode to the the end process script that would move the bed for filament change and the some to add to the start of the next process to put things back where they need to be..
https://www.simplify3d.com/support/tuto ... f-a-model/
Re: Pause at layer
Posted: Fri Aug 31, 2018 8:50 pm
by PeterMorphett
Yes please at a simple pause at layer height setting, and offset the hotend without it also turning the hot end off, or bed temp.
Pete.
