Phgeis wrote:I am fighting with mt 2x on .2 mm . Could you give me a hint where your importations are around? I use right now
Nozzle .4
Width .36
Multiplier 1.1
I am not totally satisfied with the result
These seam totally different from your .1 values. Can you help me underfunding these parameters?
Nozzle is of course pretty much whatever your nozzle diameter is.
Width is the size that the extrusion comes out of the nozzle. I think that's including the width it gets squished out to. So it's reasonable to assume it will be always be larger than the nozzle diameter. This setting will effect the amount of spacing being shells.
Multiplier will change the amount of plastic coming out of the nozzle. ABS tends to expand more than PLA. So this value for ABS should be smaller than PLA. Also the smaller the layer height the smaller this value should be.
