The inside-out vs outside-in setting toggles what order the perimeters are printed. Infill will always be printed after the perimeter. You can see this in the previewer.dodgersfan24 wrote: On the layer settings, there is an option to print layers Inside-out, or Outside-in. Mine had Inside-out by default. If you switch this setting to Outside-in, it solves this problem.
I printed out a small statue with lots of detail, and it had 0 flaws between these layers. And it had 8 processes. I printed a 5.5 in tall Buddha statue in 7 hrs at high resolution. I'm now able to print out another large piece with confidence.
I'm glad you're feeling more confident again!
