Hi, does anyone have any alternative starting G-Code to the skirt...
I really would like to simply print a straight line down the side or across the front to get extrusion working properly before starting the print instead of strings being dragged across my print whilst the printer is trying to lay down the skirt. I can't understand why the skirt is necessary (unless used as a brim) when we can simply get the first part of the print extruding properly with a straight line which doesn't use up much of the print bed?
Not an expert in G-Code, any help appreciated...
Many thanks, L
