dodgersfan24
Importing Small Scaled models.
Usually I create and edit models with blender. I set it to metric, and scale to 1. When I import my STL's, it says
Part appears to be extreamly small and may be in inches format. Would you like to automatically scale to millimeter format?
I click no as always, then change scale from 1 to 1000. And go from there.
But now in 3.0 it scaled at 100, and cant increase it to 100,000. I can only do it to 99999.00,
Is this an issue for anyone else? Can I fix this in blender side?
KeyboardWarrior
Re: Importing Small Scaled models.
dodgersfan24 wrote:Usually I create and edit models with blender. I set it to metric, and scale to 1. When I import my STL's, it says
If you export your model in mm units for the STL, then it shouldn't need to be scaled once in Simplify3D
dodgersfan24
Thank you, that helps.
