MacGyver2004
The "Default" view is rotated 180 degrees
In the preview window my model prints 180 degrees rotated from what the preview window shows. I can't for the life of me figure out how to fix it so when I click the "default" button it shows up correctly. Even the build plate graphic is rotated 180 degrees.
Re: The "Default" view is rotated 180 degrees
Click "edit process settings", go to G-Code tab, and enable the flip XYZ axis options until it looks correct
