slipshine
My first 1.1.5 print
I have attached my first 1.1.5 print.
It worked without incident.
It was just under 3hours and I printed from the USB.
1st Print
1st Print
lllusion
Re: My first 1.1.5 print
Very nice indeed!
Are you using the same settings u posted for the 1.1.3 print? :o
slipshine
Pretty much the same. Other than adjustment for fillament.
Are you having any luch with it?
lllusion
I've been printing some calibration cubes w tht settings, but been getting 'teeth-like' edges. I'm using PLA at 190degreeC though. And I haven't tried printing organic shapes yet. Shld be giving it a go to see hw it turns out. :)
slipshine
You might try a little lower temp for pla.
Also make sure you have a fan running to cool the layers.
When you are doing test cubes the speed slows way down and if you dont
Get the layer cool you can have problems.
http://www.thingiverse.com/thing:18271
Is a good test model when printed at about 55 to 65mm tall.
And it doesnt use much material.
Keep me updated.
Good luck
