skelator
V3.0 Printer profiles & process
Reaching to v3.0 is a miles stone so congrats, just want thing that I use to have with Repetier host are not available with S3D. I own multiple printer (Kossel/Mendelmax/Flashforge Dreamer) each time I change the printer type (view configuration assistant) it will wipe out my saved process which is kinda annoying having to do them all over again :)
Skel
Re: V3.0 Printer profiles & process
You just have to use the configuration assistant once. After that you can simply select the profile from the drop-down list after clicking "edit process settings". No need to use the configuration assistant anymore.
This video may help: https://www.youtube.com/watch?v=eZ7HFPY1wog
