JoeJ wrote:Ok, well if you can answer all of the questions, then I can help. Only guessing if you only answer 2 of 5 quesitons
Sorry, i must have missed all of them because of the language barrier
JoeJ wrote:You probably just need to adjust your axis directions and zero position in the software. It's pretty easy.
First, open the machine control panel and click Home All. Where does the toolhead go to (i.e. front left)
Machine does homing X,Y and then Z with autolevel, toolhead is left at center of the print plate
JoeJ wrote:Then, click on the Communication tab and send the command "G1 X0 Y0 Z0 F3000". This will move the toolhead to (0,0,0). Does the head stay put after sending that command or does it move somewhere else? You need to know this information to make sure you define your origin position correctly.
doing that goes to 0,0,0, as expected, the end result is the same as in the picture, X right, Y back, Z touching bed
JoeJ wrote:Then click on the Jog Controls tab and jog the X, Y, and Z axes using the buttons that are labeled +X, +Y, and +Z. Which directions does the toolhead move for each? For example, when clicking +X 10mm, does the head move to the left or to the right?
+10 X: nothing
-10 X: left
+10 Y: goes to back
+10 Z: goes up
PS as i stated before, i have X inverted in firmware.
JoeJ wrote:Once you do each of those test, we can tell you what to set
Done, am I still missing any questions?
