It sounds like the extruders are trying to purge before they are up to temperature.SLICE_FOR_FUN wrote:Hello,
I guess you have to downgrade your firmware. I have 1.10/V2 and it is working (Try really small numbers like 0.00000000001 before).
I have a Cube Pro Trio and try to make it working with Simplify as well. I'm using the profiles posted here, but still got problems:
-before the print starts, while the extruders are in the parking position and heating up, there is a strange sound (knocking). I guess the temperature and extrusion rate are not correct. After this there is often a filament error... and the print doesn't start.
-If the print starts, qualitiy is bad, because the extrusion rate is to high
someone an idea?
keep on trying....
Does this happen in single material prints? or just multi? Post a factory file so we can have a look.
