I'm having a problem that just recently started, where I can't connect to my printer (RAMBO controller USB 2.0 connection) via a laptop running Ubuntu 14 with Simplify3D. I can connect to it on another laptop running Windows 7 with the Simplify3D machine interface. I can also connect to it on the Ubuntu laptop if I use the console tool from the Arduino IDE. I've checked that the Baud rate and the port name are correct in Simplify3D.
This is a recent problem because I have been able to connect to the printer (and print happily) using the Ubuntu laptop previously, but when I applied some system updates for Ubuntu, I started being unable to connect. The message I get when trying to connect using the Simplify3D machine interface on the Ubuntu laptop is "WARNING: device unplugged while connecting to port".
Any suggestions? My setup:
Ubuntu 14 32 bit
RAMBO 1.3 - Marlin firmware
Simplify3D 3.0.2
