I can not seem to get the coordinate axis to display on the build screen. The blue, red and green arrows. I have selected the view from both the top menu and the toolbar, Am I doing it wrong?
The selector on the dropdown menu and the button on the toolbar are actually alternate way of toggling the XYZ axis marker on and off. Selecting from both will actually turn ON then OFF again.
I am having the same problem. On one PC it works fine and i can them on and off but on my other PC they off. I have tried from both the menu and icon (the icon changes colour when selected via the menu or button). All the other buttons function correctly. Is there some other setting to enable this?
Just go to View > Coordinate Axis and make sure that is checked. If it is, then it's definitely displaying somewhere (but if you're origin offset settings are weird, then it may be shifted)
I have checked the origin offset and they are zero. I zoomed out and still couldn't find them. I tried adjusting the origin offset on the working machine and could see them moving so am checking the right thing.
