But it is the same problem with a skirt.
I want to use skirt or oozeshield for protecting the object to avoid the quick cooling out of ABS. Doing so, I have no warping.
Creating a 2nd process the skirt also stopps with the first process.
I can't see a plausible reason for this.
In version 2.2.2 this was possible but there was an other issue, it lets a gap between the processes, but not on level of the change-value, the end of the first and beginning of the second process in the attached picture is 5 mm.
The old version is history but I expect that S3D will fix this new bug as soon as possible. I need the multi processes for changing a lot of things as infill, speed and other parameters to improve the print-quality.
- Skirt V 222 5 mm.jpg (6.55 KiB) Viewed 8860 times
