mcbutler
Spiral Mode Z axis movement not regular
Hello All,
Fairly new on this software 2 weeks experience.
I am trying to use spiral mode to print a 'round' from a gun (bullet).
The process starts well but by the time around 10 sprays have been completed it is obvious that the Z axis is stepping down at a rate higher than the extrusion width and the extrusion starts to miss the existing structure and eventually fails altogether with the extrusion just feeding into thin air.
Do I need to change a setting, maybe the Machine setting, to cartesian (circular volume).
Any ideas would be appreciated.
I am on a Wanhao Duplicator 4 dual machine that otherwise performs faultlessly at all times (might regret saying that).
Thanks in advance.
Happy New Year to you all.
Mark (UK)
Re: Spiral Mode Z axis movement not regular
Perhaps you are under-extruding? Or the overhangs are too large to only use a single outline?
mcbutler
Hi, thanks for the reply. No overhangs to speak of just a vertical cylinder really.
Under extruding is a possibility which I will check.
Biggest thing is I can actually see with the naked eye the gap between the extruder and the model grow with every revolution!
Will update later on when printer has finished its current project.
Regards,
Mark
