I have a model that has been split into 2 sections, as the upper section must have a different infill than the lower section. The 2 process are the same except for infill and Skirt/Brim (turned off for Upper)
The Problem:
1) The skirt/brim does not print
2) The print cooling fan turns on as soon as the print starts, (set to start on layer 5) but then turns off after the 1st or 2nd layer.
3) The HBP temp is using the wrong temp. Set to 100c for first layer then down to 90c on 2 layer. It's starting with 90c.
I'm sure I'm setting this up wrong, but I can't find any instructions for the proper way to make this work.
The Question:
Is this possible, and if so how can I get it to work?
WBR
RJ_Make
