Where do you define the file extension, I found it once now I can't. Help
I want the system to default to the extension for my printer so that I don't have to manually change it each time I save a file.CompoundCarl wrote:What file extension do you want? I think it already uses the standard file extension for most file formats..
.g3dremCompoundCarl wrote:What file extension does your printer use? For example .x3g? .gcode?
Actually, It defaults to .gcode which I have to change every time I save a file, which is why I asked "how do I change the default"?CompoundCarl wrote:The stock profile for the Dremel printer already exports files using the .g3drem extension. So just use the stock profile as provided by S3D (you can re-download it by going back to Help > Configuration Assistant)
This is not the case for me, I have a dreamer which reads *.g not *.gcode, and when i save the file it always saves as .gcode unless i manually change it. Im using the stock Dreamer profile so it may be that it is set incorrectly ?? .I wish there was a place in options to specify a default save extension.... its not major but would be nice.CompoundCarl wrote:Their stock profile saves as .g3drem. I'm using it right now. If you modified their stock profile, it's possible you changed that, so that's why I recommended re-downloading it.
One other thing to note - when you click "Save Toolpaths to Disk", it may prompt you with a name that ends in .gcode, but it will get automatically converted to a .g3drem when you actually save it. This is the same with many other file formats too. Some even export both the .gcode file along with the final file format so that you can keep both for reference (this is mostly used for binary files, since the final binary file is pretty much unreadable).
{EXTENSION "g"}
