I am having problems with the side of holes being printed under size.
You can now adjust the model size in the X and Y plain. However I would love it to only work on the outer perimeters. You could then have a different size adjustment for inner perimeters like holes.
E.g. you could make the model outer perimeters (xy) 0.2mm over size, if the model was coming out of 0.2mm under size. And make the inner perimeter 0.4mm under side if holes were printing 0.4mm small.
This would massively help for print accuracy.
Thank you.
