NoHands
my object is hollow?
i brought a model of a mermaid and its hollow when i try print, it should i just up the supports?
or is there a way to fill it?
i'm a quadriplegic on life support with no movement but my chin
Check out my website www.higherthansuperman.com
dsegel
Re: my object is hollow?
What are your infill settings?
NoHands
40%
Can you post the factory file? It's kind of hard to give advice when we can't see the model...
NoHands
factory file is 41mb how can i shrink it?
Are you sure the file is the factory file.....suffix .factory ....and not the shape file.....suffix .stl ?
.stl files tend to be large, but once imported into S3D, the exported factory file is considerably smaller.
The factory file can be created from the Files dropdown menu===>Save factory file as
If the factory file IS that big, use WinZip to reduce the size.
NoHands
the factory file is 22mb zi[pped grrrr
any other ideas?
... dropbox.
H.
NoHands
... Iam verry sorry, but Your factory doesn't work.
After opening the factory the program stops with only the message like shown in the attached picture.
