Hi, just started using the AXIOM and used the same settings from CURA in to S3D. IT seems to be going OK but I'm struggling to get a decent top finish. Has anyone had anything similar?S3RIOUS74 wrote:I have the axiom and I am printing successfully with Simplify3D. I used the start and end Gcode from cura (same as from astroprint). The only thing I added was a move over in the X direction after auto leveling. Otherwise the nozzle will crash into the build tray retaining rail when it goes to print. Then I just used the same material settings (speeds, temps, retraction, etc.) that I was using in cura, and I was good to go.
Hope that helps.
