adge
Adjust print speed for overhangs
Thu Mar 10, 2016 2:08 am
I've found that slowing the print speed right down produces the best overhang results, however printing the entire print or relevant layers at such a slow speed is pretty inefficient. By creating a setting that would allow users to adjust the print speed depending on the overhang amount would greatly improve print quality.
Most of the community uses additional cooling fans to overcome overhang curling or sag, but this seems unnecessary when this setting could solve this.
The software would detect the overhang amount for each section of every layer, and when the overhang exceeds X amount, it would slow the print for that particular section of the layer and then continue at it's original speed after the overhang is printed.
kejocu
Re: Adjust print speed for overhangs
Mon Mar 14, 2016 8:43 pm
Excellent idea!
Zapperke
Tue Mar 15, 2016 11:20 am
+1
Would be great!
NitroXpress
Tue Mar 15, 2016 2:29 pm
Would be perfect !
KC_703
Sun Mar 20, 2016 3:19 am
Good idea.
As a workaround for the time being, use multiple print processes to adjust print settings for any given section. So for the section with the overhang, use a process with a slower print speed. Then add a second process with normal print speeds... its meticulous, but should work.
See this write-up:
https://www.simplify3d.com/support/tuto ... f-a-model/
VIdeo tutorial:
https://www.youtube.com/watch?v=EbQfifnzL4Q
Xtroodler
Tue Aug 30, 2016 3:44 pm
Googled this today and found this topic. Disappointed to find this isn't a standard thing already. Definitely got to give this a +1.
TMeyer
Fri Sep 02, 2016 8:21 am
+1
timmah1991
Tue May 09, 2017 12:02 am
Xtroodler wrote:Googled this today and found this topic. Disappointed to find this isn't a standard thing already. Definitely got to give this a +1.
Same and same. Get on it, S3D.
ViperZ
Thu May 11, 2017 4:12 am
Hi
How is the judgment condition in the figure below?
