Hello,
Somehow the new prints made with S3D start to print off the plate at minus X location, I went back to a previous print with the same part I did with S3D and prints fine.
Looking at GCODE the failing prints have some negative values on Y on the failing prints even thought the problems shows on X axis where it starts at -X.
I could not find any changes in the process that will show this problem. One thing I did I loaded the software in a laptop so I will connect with a USB to the printer to fine-tune the printing setting, since I normally printer over the Ethernet, I never connected the printer to the laptop since the printing problems showed up.
Here is part of the Gcode that shows the good and the failing prints:
Good print:
G90
M83
M106 S0
M140 S70; set bed temperature
G28 Z; home Z
T0
G1 Z20 F900; Move Z down 20 mm
G28 X Y F900; Move XY
M190 S70; wait for bed to reach target
M109 S251; wait for extruder to heat
G28 Z; Re-home Z
G92 Z.10 F225; Slight move for Z
G1 E15 F900; purge right;
G92 E0; reset virtual position
G1 E-8.0000 F4200
G1 Z0.486 F1002
; layer 1, Z = 0.286
T0
; tool H0.286 W0.600
; skirt
G1 X35.300 Y0.775 F4800
G1 Z0.286 F1002
G1 E8.0000 F1260
G1 X35.346 Y0.665 E0.0031 F1200
G1 X35.665 Y0.346 E0.0119
G1 X35.775 Y0.300 E0.0031
G1 X264.225 Y0.300 E6.0222
G1 X264.335 Y0.346 E0.0031
G1 X264.654 Y0.665 E0.0119
G1 X264.700 Y0.775 E0.0031
G1 X264.700 Y199.225 E5.2314
G1 X264.654 Y199.335 E0.0031
G1 X264.335 Y199.654 E0.0119
G1 X264.225 Y199.700 E0.0031
G1 X35.775 Y199.700 E6.0222
G1 X35.665 Y199.654 E0.0031
G1 X35.346 Y199.335 E0.0119
G1 X35.300 Y199.225 E0.0031
G1 X35.300 Y1.375 E5.2155
G1 X35.300 Y0.775 F1200
; inner perimeter
G1 X38.100 Y3.100 F4800
G1 X43.115 Y3.100 E0.1322 F1080
G1 X42.734 Y3.381 E0.0125
G1 X42.256 Y3.792 E0.0166
G1 X41.798 Y4.248 E0.0170
G1 X41.391 Y4.721 E0.0165
Failing print:
G90
M83
M106 S0
G28 Z; home Z
T0
M109 S252; wait for extruder to heat
G28 Z; Re-home Z
G1 E-8.0000 F3360
G1 Z0.486 F1002
T0
; skirt
G1 X35.300 Y-0.225 F4800
G1 Z0.286 F1002
G1 E7.8000 F1008
G1 X35.346 Y-0.335 E0.0033 F900
G1 X35.665 Y-0.654 E0.0124
G1 X35.775 Y-0.700 E0.0033
G1 X264.225 Y-0.700 E6.2680
G1 X264.335 Y-0.654 E0.0033
G1 X264.654 Y-0.335 E0.0124
G1 X264.700 Y-0.225 E0.0033
G1 X264.700 Y200.225 E5.4998
G1 X264.654 Y200.335 E0.0033
G1 X264.335 Y200.654 E0.0124
G1 X264.225 Y200.700 E0.0033
G1 X35.775 Y200.700 E6.2680
G1 X35.665 Y200.654 E0.0033
G1 X35.346 Y200.335 E0.0124
G1 X35.300 Y200.225 E0.0033
G1 X35.300 Y0.775 E5.4723
G1 X35.300 Y-0.225 F900
; inner perimeter
G1 X38.100 Y2.100 F4800
G1 X44.984 Y2.100 E0.1889 F855
G1 X44.921 Y2.123 E0.0018
G1 X44.340 Y2.374 E0.0174
G1 X43.778 Y2.671 E0.0174
G1 X43.247 Y3.004 E0.0172
G1 X42.736 Y3.379 E0.0174
G1 X42.253 Y3.794 E0.0175
