Hi There,
I tried using creator software with UM2. below are the settings
Layer thickness: .1mm
Extrusion width: manual, 0.4mm
Multiplier: .9 (I have been using this with Slic3r based on my calibration)
Z-offset (tried from 0 to .04)
The issue is the first layer does not stick properly. I am using Kapton tape @70C temperature. I even upped the multiplier to 1 and found the same issue. The first layer material comes out but it is grossly underextruding.
When i changed the layer height to .2 the first layer sticks well. Also, i feel that the infill extrusions are pretty smooth and solid but the perimeters are intermittent.
Any suggestions,
Sam
