Which may be the problem. Temperatures, physical dimensions, etc will translate between the packages....but things like Extrusion multiplier (note I'm not sure if Cura has such a parameter, but I hope you get the point!) may not translate directly as they will be used and handled differently by the code in the slicer software.Obviously, but I went through every setting on every tab to see if there was anything out of sync. they're as close as they can possible get given the inherent difference in the software.
