New print report: HUGE IMPROVEMENT
Coasting - disabled
Retraction - 2.0mm
Extra Restart distance - 0mm
Extrusion multiplier - 0.95x
First layer height - 80%
First layer width - 125%
First layer speed - 35%
Outline overlap - 30%
Temperature - 210 for first layer then 191 after (printer kept dropping to 189. wanted to keep it at 190)
Allow Gap Fill - 10%
Layer Thickness - 0.3mm
Solid Top layer - 4
Solid Bottom layer - 4
Outline shells - 1
Minimum infill - 0.4mm
Print islands without optimization - enabled
Printing Speed - 3600 mm/s
Outline Underspeed - 50%
Solid infill Underspeed - 70%
X/Y Axis Movement Speed - 5400 mm/s (was 3600 mm/s before)
The issue with my printer was that when it was crossing open spaces, no matter how fast the extruder was covering the distance, it was always oozing out about 1mm of filament with 1mm retraction distance setting. So I put 2mm for the retraction distance.
I think once I set the retraction distance to 1.8mm the print will be perfect.
