tetranet
Change model Printer
Hello,
I have 4 3d printer. How could i change my printer in S3D please ?
Tetra
razster
Re: Change model Printer
The very first time you use a printer, go to Help > Configuration Assistant, and select your printer from the list. This will load the profile for that printer and save it for later. So you only need to do this ONCE.
After you have done that for all your printers, anytime you need to switch between machines, just click "edit process settings" and choose your printer name from the profile dropdown list at the top and click OK
