I am printing this model shown. It is being printed in a heated enclosure at 65C. The overhangs are looking like this, even with support. They just want to curl upward and that intereferes with the next layer. I thought the heated chamber should prevent this from happening as it slows the cooling process of the plastic thereby keeping the curling from happening?
wall thickness about 0.125"
Print params:
speed - 100mm/s, 50% outline speed
print temp 230c
E3D hotend volcano with 0.6mm nozzle
heated chamber at 65c
layer width is 0.78mm
0.95 extrusion multiplier
0.25mm layer height
20% outline overlap
45% support density with 2 dense support layers at 70%, horizontal offset 0.40mm
I may try this with the heated chamber off.
