AK_Eric
Re: Tree like support etc
In a pinch, Meshmixer will do this, fyi: You can create the supports in meshmixer, then export them as a stl to bring into S3D.
Having that as an internal option in S3D would be darn nice though.
Bots:
Makerbot Replicator 2x / Sailfish on Mightyboard
Custom C-Bot / RepRap Firmware on RADDS
Custom Tevo Little Monster / RepRap Firmware on Duet
salem160
Treelike support
Greetings;
my feature request is very simple is to add treelike support as in flashprint it is helpful in many ways for some special builds
and could use Wifi connections to some printers !
Re: Treelike support
nakwada
Hello,
Would also love to have this feature inside S3D !
The problem with Meshmixer's stl exportation is that when you open the stl file in S3D, the treelike supports have missing layers. It forces me to upload the model and fiw this through netfabb.
Maybe I made a mistake somewhere and forgot to tune a setting, if so please tell me guys.
Printers : Stratomaker / 2x Ultimaker 2 / Kossel Mini / Zonestar P802M / Liquid Crystal / DaVinci Jr / Form 2
Creator of the metamorph project
Company : http://www.anaon-industries.xyz
pjones
+1 for this feature
fritts
+ 1 This really should be useful in limiting excess material usage as well.
Z-Axis3D
+1
I use meshmixer for this too when I need it but it would be really great to have it right in S3D
arhi
meshmixer (tree like) type support
if you ever tried autodesk meshmixer and seen the way how it create suport I'm sure you liked it :D
the tree shaped support structures are faster to print and use way less plastic then standard columns ... they are bit harder to print and require properly calibrated printer but having the option to generate support like that in s3d would be super nice feature
Embed M117 codes into G-Code
open source and unlicence
jballard86
Re: meshmixer (tree like) type support
I agree, even if it is much simpler.
Jorim
Tree support
I was wondering if there ever will be something like a tree support kind of thing in the future. I've seen multiple questions about it, and I'd think it would be a nice feature.
