GeorgB
Multiple Process: Infil Patterns
I have 2 models. One should have rectlinear and the other Honeycomb Infil Pattern.
I defined 2 processes A and B from 2 different Profiles PA and PB (because one profile can only handle one type of pattern).
Now I select the models.
Now I "Prepare for print" for both models with the process A for part A and process B for part B.
Finally always the pattern of the "prepare for print" is active.
(no difference "Continous printing" or "sequential printing". )
Where is my mistake?
Re: Multiple Process: Infil Patterns
I've just tried the same, following what you did....and the two infills are different as expected.
Can you attach your factory file and I'll take a look at it.
GeorgB
@Doug thanks for mail - what do you mean with factory file? the *.gcode? *.stl?
Load your models and profiles as if you're ready to slice, then on File menu====>Save factory file.
The file will have the suffix .factory. It contains everything needed to replicate exactly what you're trying to do.
Attach to the post using the "Upload attachment" at the bottom of the posting page.
GeorgB
Doug, sorry - I am quite new ... and was not aware of this feature !
Thare are just 2 parts ..
Thanks for your help!
kippe.factory
(25.34 KiB) Downloaded 277 times
Saving the factory file is the standard way of saving how you set up and printed something. Once saved, you can load at any time and be able to do an identical print.
And I think I've spotted a few strange things in your file.
Firstly, I get an error when reading the profiles in. Once for each profile "Failed to parse XML file" This may point to the cause of your problems..but I'm not sure. Clicking OK on each error results in everything loading.
Checking out the two profiles, neither had a model selected. I set one model to each profile.
I then spotted both profiles had rectilinear infill set. I changed one to honeycomb.
On slicing, one had rectilinear infill, and the other had honeycomb infill as I would have expected.
Try loading the attached updated factory file and see if you get a difference. I'd also try loading the factory file you saved to see if you get the same two error messages. If you do, then your original settings may be corrupted.
kippe_fixed.factory
(25.22 KiB) Downloaded 325 times
GeorgB
I have also those 2 errors.
argh - I made an user error: I selected the models on the wrong place.
Sorry it was my mistake, everything is ok!
Thanks for your time..
GeorgB
PS: I found out the reason for the errors:
I had german letters in the comments of the script commands (äüö..)
thanks again..
