good fellow, I have a little problem, I have the s3d with qidi and can print without problem, now I an left for a time, a sirius moebyus and connect putting it at home there is no problem, give it a warm bed and one estrusor and no problem charge filament nor, the problem I have when you start printing the piece does not come out filament, it is very rare, only leaves mini balls filament me and noticed that the wheel that drives the filament when printing not going down but not where the problem with s3d, because if I give charge filament there is no problem, see if someone can enlighten me on the road
and proven solutions and do not work give me https://www.simplify3d.com/support/prin ... t-of-print
Extruder was not primed before beginning the print
Nozzle starts too close to the bed
The filament has stripped against the drive gear
The extruder is clogged
