Hello!
I create a cylinder object 25 mm x 25 mm. I set the shells to 1 and the infill to 0% and the Extrusion Width is 0.50 mm. When I print using my Taz 6 I get a pretty print using PLA. The walls are really thin but the layers are uniform and there are no pits, holes or blobs of plastic on it. The surface quality is really good and the object is surprisingly sturdy and there is no warping.
I go and make the same object but now I purposely make it's walls 0.5 mm thick and I get this melted looking thing. It will do these crazy back and forth movements across the 0.5 mm walls like its trying infill it or something and it leaves big blobs of plastic everywhere.
What is going on here?
I have to print some really thin walled objects and I know the dern printer can do it. Now why does Simplify3D keep making a mess of it? Is there a button somewhere that will turn off the "I'm smarter than you" features and just print what is there?
Thanks,
--jb
**Note: I have reduced the extrusion width and I still get terrible surface quality. I should get as pretty a print as I do when printing with a single shell and no infill.
