I'm encountering a new problem after swapping out to new nozzles. Now ALL of my prints where there is any jump between open space i get a perfect line between these points. (the same lines you can see in the S3D software labeled 'travel moves') no matter what settings I change I am unable to make ANY change to those strings, they are literally the same size as spider webbing and all perfectly strung.
I had a number of problems prior to upgrading/replacing my nozzles, but stringing wasn't one of them. I followed the Print Quality troubleshooting guide to reduce stringing with no luck.
My retraction distance was moved from default 1mm all the way to ~10mm before it started retracting TOO far (that was a headache)
Retraction speed has been moved to 6000 mm/min w/ no luck
Temperature has been tried between 230-190 before it was getting too cold to feed filament.
Movement distance on my calibration block was no more than 5mm with strings between every layer consistently.
so I'm wondering what's next?
I have a PowerSpec 3d Pro 2 printer (essentially a Micro Center knock off of the Flash Forge)
if its relevant these are the nozzles I swapped out to:
https://www.amazon.com/gp/product/B01GG ... UTF8&psc=1
