Landerbach
[DONE] Save FFF config files
What I would like to see is:
The possibility to save several FFF config files like so:
LeftExtPLA
RightExtPLA
LeftExtABS
RightExtABS
LeftExtPVA
RightExtPVA
In this way I only have to configure this files and reuse them over and over.
Kind regards,
Joost
Re: Feature request: Save FFF config files
Joost,
I believe you can export the FFF profiles right now. For example, if you exported the 6 profiles you listed, all 6 of those would then be automatically added to the "Select profile" drop down list. You can make changes to those files and then you can easily load the settings whenever you want using the drop down menu.
