Amidatti
Set camera pivot to model, one-click Z offset
Hi there! I have recently begun using Simplify3D and greatly appreciate the fine control it provides over print settings, but I have a couple interface questions.
I am wondering if it is possible to set the camera pivot to a model's center. Typically I have several models arranged on the virtual print bed, so the ability to rapidly set the camera on any one would be quite handy.
Also, when a model loses contact with or passes through the floor plane, is there a way to level the lowest point with the floor plane automatically without eyeballing, or without changing the X and Y coordinates for all models the way "Center and Arrange" does?
Thanks for any tips.
brian442
Re: Set camera pivot to model, one-click Z offset
I think the camera rotation is fixed, but for your second question, you can go to Edit > Drop Model to Table to lower a model to it is perfectly touching the table surface
kabali16
Amidatti wrote: Also, when a model loses contact with or passes through the floor plane, is there a way to level the lowest point with the floor plane automatically without eyeballing, or without changing the X and Y coordinates for all models the way "Center and Arrange" does?
Similar to what Brian said, I would suggest you use Place surface on Bed feature (Edit Menu). Once you click this, you will be able to select a single face (triangle) that you want to position on the bed. This will be a little more accurate
Kabali daww!!
Prusa i3 | Kossel
Simplify3D | Cura | Repetier Host | Octoprint
