Fallen Munk
[ALREADY ADDED] Smooth Z Ramping
Is there any way to implement smooth Z ramping instead of just a vertical jump that leaves a seam? With a ramp speed and distance option that can be set in the software? I'd find that very useful.
brian442
Re: Smooth Z Ramping
Check out the corkscrew printing mode (vase mode) on the Layer tab.
Fallen Munk
brian442 wrote:Check out the corkscrew printing mode (vase mode) on the Layer tab.
Thanks, I'll give that a shot on this model. I tried it once with a different model and the infill was all messed up.
arhi
Fallen Munk wrote: I tried it once with a different model and the infill was all messed up.
that mode will not use infill at all, it only prints solid layers and walls, infill is zero
Embed M117 codes into G-Code
open source and unlicence
