I've noticed you have introduced Dremel Idea Builder into the Configuration Assistant. I have a Dremel 3D40 Idea Builder and can not seem to connect to it. Anyone able to connect or do I need to export to save file and copy to card?
-SRANEY
I have the same problem. I can download to the SD card, only.sraney wrote:I've noticed you have introduced Dremel Idea Builder into the Configuration Assistant. I have a Dremel 3D40 Idea Builder and can not seem to connect to it. Anyone able to connect or do I need to export to save file and copy to card?
-SRANEY
