I'm using the same settings and as you can see by the picture, the quality is far worse on the 0.5mm wall. I've tried to adjust a few things but no success yet. Any pro's around that would be able to help? Thanks
I'll send you a PMhorst.w wrote:No, that was the right tool for the 1st process
setting 0,40 mm nozzel
ExtrusionWEidth to "Auto" = 120% from nozzle = 0,48 mm
and for the 2nd process
setting 0,40 mm nozzle
ExtrusionWidth to "Manual" 0,44 mm
BUT !!!
You haven't determined the procecces in the tab Advanced with STOP and START for each . P1 must be stoped and P2 must be started.
Also the whole object will be printed with the first process
0,44 is also wrong as 0,48 mm EW for a 0.50 wall.
Tomorrow more advices.
PS:
You have attached the new factory twice time, but it seems to be the same.
Also this factory shows no Stop / Start - values in Tab Advanced, therefore the whole object will be printed as P1
The first object you have shown is an inconstistend construction, will say, the wall thickness is variable. That seems better in the new example so we can discute about it.
I'm sorry but I have only eMail but when you need urgent a solution, we can go to PM here. I'm living in Western Europe that makes UTC +2 (winter UTC +1) and now we are near 11 pm
